aaP_zoran_dj Hello, I wanted to configure the DNS settings, but apparently something is missing in my panel. Where can I find the Domains menu? Panel version is 7.0.11 Due to the following error, it is not possible to update the panel: Thanks
aaPanel_Kern Hello, please try to repair the panel is normal? rm -f /tmp/update_to7.pl && curl -k https://node.aapanel.com/install/update_7.x_en.sh | bash
aaPanel_Kern Hello, I suggest you check whether the nameserver is set up? You can check this file /etc/resolv.conf If not, you can use this command to configure echo "nameserver 8.8.8.8" >> /etc/resolv.conf It is also recommended that you check whether the server network is normal? Is there an error message or screenshot? aaP_zoran_dj
aaP_zoran_dj Hello, after entering the command you provided, this window appeared automatically a minute later, and the update was successful. By the way, I can now see the domain menu. Thank you very much!
