aaP_ngbaze100 Please how can i enable phpadmin public , i have tried 1000 time not enabled. Please help
aaPanel_Kern Hello, check if the nginx configuration only allows 127.0.0.1. If so, please delete it. aaP_ngbaze100
aaP_ngbaze100 Next, i can't able to change the phpmyadmin PHP version. how can i change , if i tried it's automatically back to 5.4
aaPanel_Kern Is this file normal? /www/server/nginx/conf/enable-php.conf location ~ [^/]\.php(/|$) { try_files $uri =404; fastcgi_pass unix:/tmp/php-cgi-83.sock; fastcgi_index index.php; include fastcgi.conf; include pathinfo.conf; } aaP_ngbaze100
jaehyun1122 aaP_ngbaze100 hello It seems to be the same problem as me. Can I try the next one? !! It is recommended to back up before trying. Remove the file in the path below. /www/server/nginx/conf/enable-php.conf Restart the panel in the home. Change the php version on the phpmyadmin interface!
