Jimmy Hello, I install the aaPanel in 7 October the version 6.8.4 and now some days later I have the version 6.8.5. Updates are auto now? I remember that I didn't update manually.
aaPanel_Jose aapanel_user Jimmy This should be caused by the panel background task checking that the panel access failed and automatically triggering the panel repair task. In the next version, we will consider removing the automatic repair
Jimmy How I can stop this auto update in version 6.8.5?. I want to stop this because I use aapanel to a unstable distro and auto-updates may cause problems.
aaPanel_Jose Jimmy I have commented it in the new stable version, you can comment this line manually /www/server/panel/task.py line 486 change update_panel() to #update_panel() and restart panel
aaPanel_Jose 0Zero The panel will not automatically update the panel. The above code is to take a repair action when the panel may not work. It has been removed.
