adhitya [root@adhislims ~]# service mysqld start Starting MySQL... ERROR! The server quit without updating PID file (/www/server/data/adhislims.pid). [root@adhislims ~]#
aaPanel_Kern Hello, I suggest you check the mysql log, what is the reason You can also use this command to check: curl -k https://www.aapanel.com/script/mysql_check.sh | bash
aaPanel_Kern Solution: https://www.aapanel.com/docs/faq/Databases_Related.html#failed-to-open-log-file-mysql-bin-000004-errno-2
