ZaheerAhmed When i try to open panel i get "Your connection is not private" error. In Global Setting the ssl is configured correctly. I have tried bt 27 but still problem. I am using panel version 8.0.2 How to solve this issue ?
aaPanel_Kern Hello, This is normal. The default is to use a self-signed certificate. You can just inform it. Reference: https://www.aapanel.com/docs/Function/Tutorial/panel_access_using_domain.html ZaheerAhmed
