Good day everyone, today I decided to make my review about aaPanel.
To be honest, aaPanel is the best Linux control panel that I have ever used since I became a developer, it makes my jobs easier, flexible, clean code writing, much better than cPanel why? Because coding on aaPanel makes life easier and gives you a better understanding of your codes and errors found in the code... aaPanel also has code auto-complete, which means when you are coding or developing using aaPanel it auto-suggest for you.
In terms of security aaPanel is very strong I also try in hacking my website with malicious java scripts, but I got an error message from aaPanel direct on my website saying: Your request has an illegal parameter and has been blocked by the webmaster settings!, that's great website security.
In terms of website speed I rate aaPanel 100% reason?, the image below will show you my reason for rating this panel, I developed my website using aaPanel, and my codes were written professionally, because of aaPanel flexibility and coding guides.
I was able to achieve this speed and score metrics
Performance = 100
Accessibility = 100
Best Practices = 100
SEO = 100
You can also confirm that yourself from the image below and see what I am talking about.
Another thing I like about aaPanel is 100% quality file backup, which means I can back up my files on Google Cloud, Google Drive, AWS, and direct on my server, but I love using Google Drive or cloud for backup because I don't trust web hosting companies.
Many features and Plug-ins available in the aaPanel App Store, many things to explore and improve your website security, speed, caching, and many more. Thanks, aaPanel for this awesome Linux Panel.
