500 error after loggin into the control panel
Normal funcionions untill this morning. Loads login. page reloads error 500
my log:
raise value
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 1949, in full_dispatch_request
rv = self.dispatch_request()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 1935, in dispatch_request
return self.view_functionsrule.endpoint
File "/www/server/panel/BTPanel/init.py", line 575, in files
return publicObject(filesObject,defs,None,pdata)
File "/www/server/panel/BTPanel/init.py", line 1149, in publicObject
result = p.run(toObject,defs,get)
File "/www/server/panel/BTPanel/init.py", line 1315, in run
return public.GetJson(eval(fun)),json_header
File "<string>", line 1, in <module>
File "/www/server/panel/class/files.py", line 2108, in get_path_premissions
exist_tbs = self._get_permissions_tb_name(get_all_tb=True)
File "/www/server/panel/class/files.py", line 1908, in get_permissions_tb_name
data = self.operate_db(sql).fetchall()
File "/www/server/panel/class/files.py", line 1873, in _operate_db
return c.execute(sql_data)
sqlite3.OperationalError: no such table: index_tb
[2020-03-23 21:38:54,581] ERROR in app: Exception on /files [POST]
raise NotFound()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 2446, in wsgi_app
response = self.full_dispatch_request()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 1951, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/app.py", line 1820, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/flask/compat.py", line 39, in reraise
raise value
exist_tbs = self.get_permissions_tb_name(get_all_tb=True)
[2020-03-25 21:44:53,894] ERROR in app: Exception on /files [POST]
raise NotFound()
raise value
2048+0 records in
2048+0 records out
2147483648 bytes (2.1 GB, 2.0 GiB) copied, 3.06521 s, 701 MB/s
mkswap: /www/swap: insecure permissions 0666, 0600 suggested.
Setting up swapspace version 1, size = 2 GiB (2147479552 bytes)
no label, UUID=b75109b3-17b3-4d05-9bd6-84dae6b48d6d
swapon: /www/swap: insecure permissions 0666, 0600 suggested.
Thank you for any information
Have a great day
