izsurya Today I install latest version of aaPanel and SSL not working, I'm unable to install SSL it gives me error everytime. Please help me to fix the issue. DNS, NS already updated and working with old version v1.0 aaPanel.
aaPanel_Jose check if your site is set up reverse proxy or 301 redirect , if is set up ,turn off it and set ssl again. if still not work can you send your panel User,password,url to my email? zhwyeah@gmail.com, let me go into your panel and check it out.
aaPanel_Jose This error message can't check the specific problem. If you can provide the host information, we hope to check the specific problem on your server.
aaPanel_Jose solotron Not using aapanel to deploy the certificate requires manual operation, the certificate provider we use is let's encrypt, you need to apply for a certificate first and then deploy it to your weisite。
aa9000nb Same error message, I cannot verification domain SSL both of File Verification or DNS Verification. Running only on http
aaPanel_Jose aa9000nb Which version is your aaPanel? The new version has an optimized certificate application
aa9000nb aaPanel_Jose 6.1.5 Finally successed to SSL mode with Let's Encrypt with Restart The Panel first. Great Panel for me. Its simple and fast. Thanks aapanel team
