arsse Hello Please help. I have OLS on aapanel. I need like apache enable (rewrite and AllowOverride all) for one subdomain. Please help me and guide me what must to do? Thanks
aapanel_power arsse Hello, for the time being AApanel does not offer web services like OLS+Apache or Nginx+Apache or OLS+Nginx
arsse aapanel_power no. I do not want use apache+ols rather I want you say what must i do if i want to enable mode rewrite for ols and also i want use AllowOverride all for ols. please help
arsse no. I do not want use apache+ols rather I want you say what must i do if i want to enable mode rewrite for ols and also i want use AllowOverride all for ols. please help
arsse I have prestashop and it said if i want use it , i must config apache for rewrite and in apache vhost i must add: <directory> AllowOverride all </directory> I want to know what must to do for OLS?
David_Chriss Hello @aapanel_power How to do it in Aapanel? This is what I mean.. https://hidemywpghost.com/theme-not-loading-correctly-website-loads-slower/ I want to allow rewrite rule in Openlitespeed
aaPanel_Kern David_Chriss https://community.cyberpanel.net/t/htacfuls-modifications-nd-Need-Start/18537 "OpenLiteSpeed is our free open source web server, the most commonly used single site that is not often changed. This is because OpenLiteSpeed needs to be restarted to load any new .htaccess file. https://docs.directadmin.com/webservices/openlitespeed/general.html At present, OpenLiteSpeed reads .htaccess when starting. Therefore, if some new .htaccess files were created, or the existing files were modified, it would not take effect before re -loading the OpenLiteSpeed service.
David_Chriss aaPanel_Kern Hi in that documentation I see this code to automatically restart .htacess when changes made.. where to insert them in aapanel? cd /usr/local/directadmin/custombuild ./build update ./build set pureftpd_uploadscan yes ./build pureftpd
aaPanel_Kern David_Chriss This is not AAPANEL, this is just a tutorial. Use CRON to set automatic restart or manually restart OpenLiteSpeed https://www.aapanel.com/forum/d/1374-i-am-not-able-to-modify-openlitespeed-web-admin-panel-configuration/25
