aaP_boza111 I really don't know.
Usually when I'm looking for an web panel I am simply looking for something that will bring a GUI to adding domains.
I have cPanel servers for customers, and for those some customers it will only be cPanel.
For other customers or internal projects, I have tested many web panels. Referencing the free ones only:
- Webmin/Virtualmin: I find it too heavy and bulky;
- VestaCP: too many bugs;
- ISPConfig: is nice but has some features I don't find appealing at all, specially the location and path of domain files. "customer1" "customer2" and other nuisances;
- Ajenti & Sentora are also full of bugs, and poorly maintained;
I have to say overall I don't find many of them appealing or user friendly. I found aaPanel user friendly as it has few options, but relevant and accessible.
One of the major handicaps on aaPanel is that the system is poorly compatible with systemd, and still tries to use init.d as service manager.
I'm not a developer, but I really wish there was a lite control panel that would simply:
- Use the "base" or "epel" or some pre-selected repos to install software, on their pre-determined location (increased compatibility with each system, simply using
dnf or yum to install the packages, or apt if it detected a debian system);
- Would simply write the configs on the pre-defined paths and play nice with the system;
- Provided a simple and lean interface that would allow to add new domains, and add the vhost config to the proper location (in case of EL based distros, is /etc/httpd/sites-available and then add a symlink to sites-enabled if the site is enabled);
- Display a simple dashboard with info's (actually the dashboard is one of the features I most enjoy with aaPanel).
If aaPanel's FAST installation method (opposed to the compiled method) would simply use the system's package manager to install, it would be quite simpler to be compatible with newer versions. But really I've been considering more and more just deploy the config manually or with some script, than keep using this panels. I know how to configure all the services using the CLI, the panels is just for the ease of point and click.
KrzysztofMaciejewski how soon, and how do you know that, taking that info from where?
If a panel is compatible with CentOS 8 it should be compatible with all other EL8 OS's out there. It isn't because aaPanel has limitations that come from the above mentioned points.
But honestly, looking around to many problems posted on this forum, the lack of answers and lack of resolution to so many situations, I don't know how you claim it is "active and in good health".
