thiagotgc I need to create a Port Forward from port 4000 to 5000 When I add 4000-5000 it says it is invalid, and when I add 4000:5000 it accepts, updates the page, but it doesn't work and the rule doesn't appear....
thiagotgc aaPanel_Jose Fixed to add names to rules But I had to delete all the rules and add again It would be nice to be able to select several rules at the same time, to delete/disable the rule However, I keep getting an error when adding a RANGE to PORT FORWARDING Thanks
aaPanel_thisyear thiagotgc Hello, the server command line executes the following command screenshot to see if the security software is installed. If the security software is installed, close it and try to reinstall and update it. ls /etc/init.d/
thiagotgc aaPanel_thisyear [root@aapanel ~]# ls /etc/init.d/ bt fail2ban functions mongodb mysqld netconsole network nginx php-fpm-74 pure-ftpd README snmpd snmptrapd The error persists, even removing and reinstalling the SYS Firewall...
aaPanel_thisyear thiagotgc Hello, post the installation execution log to see if there are any errors.
