andiafri My panel is not working now. Try to bt on terminal but showing nothing. but my website working correctly. its possible to repair bt from terminal? 🙏🏻 And how?
aapanel_power andiafri Hello, can you login to the server now? Connect to your server using SSH terminal and check the status of AAPanel bt status
andiafri andiafri Can intry to reinstall that aapanel with instalation command? Not crash with old aapanel?
