aaPanel_Kern aaP_cimamax_00 Hi, this link can be accessed http://aapanel.cimamax.xyz:888/phpmyadmin_41232035c6160984/index.php
aaPanel_Kern aaP_cimamax_00 Hello, I can do it here, please check if the link you entered is correct.
aaP_cimamax_00 aaPanel_Kern When I search from Google Chrome automatically adds the letter ((s)) to the word http I delete it automatically adds it again I don't know why Is there a solution?
aaPanel_Kern aaP_cimamax_00 Hello, this is a problem with Google Chrome, you can try to save the correct URL as a bookmark.
aaP_cimamax_00 aaPanel_Kern Is there another browser that prefers to use as you have tried those browsers and they also add the letters (s) after http and they are Edge, Google Chrome, Safari The problem has not been solved, does it unite another solution?
aaPanel_Kern aaP_cimamax_00 Or you can use the computer version of the browser instead of the phone's browser.
aaP_cimamax_00 aaPanel_Kern Well, that problem has been solved. —- I want to know how to update something for you on the control panel in terms of PHP and other additions.
aaPanel_Kern aaP_cimamax_00 Hello, you can install the php you need in the app store. After the installation is complete, there is a Setting that can add some additional content. If not, you need to add it yourself.
farihkhoirulhuda please open using https using an incognito tab if there is a warning just continue. if you can't please use another browser and use https.
aaP_cimamax_00 aaPanel_Kern I'm not talking about installation. I'm talking about updating the additions I have.
aaP_cimamax_00 aaPanel_Kern I did my IP link aapanel with domin and server but when you enter that problem happens This is the first time I log in.
aaPanel_Kern aaP_cimamax_00 Hi, did you set the domain name in the settings of the panel? If you need to use a domain name to access, ip can not access. If you want to cancel using the ssh tool to execute the command: bt 12
aaP_cimamax_00 aaPanel_Kern I can't enter the board even once I installed the board now and when I enter the private ip that gave me, when I finished installing the board, it gives me that error.
aaPanel_Kern aaP_cimamax_00 Hello, do you have any input security entries, such as: http://192.168.247.129:7800/a36c45b0, the 36c45b0 must be fully linked.
aaP_cimamax_00 aaPanel_Kern My friend, this is him aaPanel Internet Address: http://xxx.xx.xx.xx/e443d039 This is the address that appeared when the aapanel was installed and I can't log in yet
aaPanel_Kern aaP_cimamax_00 Hello, it is recommended to restart the panel: bt restart You can check whether the log of the panel reports an error: bt 22
aaP_cimamax_00 aaPanel_Kern I've checked my ports and DNS and everything works. Please see the pictures I've sent
