saiorkrish Iam looking to integrate ssl with one of my domain hosted in aapanel. How can i generate private key i have the certificate file .crt downloaded from go daddy.
aaPanel_Jose Please refer here https://www.aapanel.com/forum/d/1413-how-to-deploy-ssl-certificate-for-website-in-aapanel
saiorkrish Thanks for the tutorial but i didn't find key file with my ssl certificate. I purchased ssl certificate from godaddy and downloaded it for Apache please find the attached image. So considering the below files please suggest.
kamranhanif496 saiorkrish When you generate CSR for ssl their will generate also private key below. Have you save the generated data?
