Hello,,
Please help me,, i got error,,
this is the error message
REQUEST_DATE: 2022-10-05 13:09:58
PAN_VERSION: 6.8.26
OS_VERSION: Ubuntu 22.04.1 LTS x86_64(Py3.7.8)
REMOTE_ADDR: 10.39.22.112
REQUEST_URI: POST /plugin?action=get_index_list
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:105.0) Gecko/20100101 Firefox/105.0
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 175, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 73, in create_connection
File "src/gevent/event.py", line 329, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 359, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 347, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 327, in gevent.gevent_cevent.AsyncResult.raise_exception
socket.gaierror: [Errno -3] Temporary failure in name resolution
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 382, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1010, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 358, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 187, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 574, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
File "/www/server/panel/BTPanel/init.py", line 1707, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1655, in run
File "class/panelPlugin.py", line 724, in get_index_list
softList = self.get_cloud_list(get)['list']
File "class/panelPlugin.py", line 366, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 117, in post
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
