If any of you want to fix your DNS problems or simply discover what is wrong with your domain name, if that is not working or so, you might want to have a look at the website DNS Inspect (link below).
This website will generate you a record that allows you to check your DNS for your domain name and gives you a score about your domain name too. Many problems can be fixed just by following they're instructions on the reports you make.
I see many people posting DNS issues and they do not check the records, this tool is free and it will allow you to make things properly, give it a go.
https://dnsinspect.com
    hadjjo you are most welcome, this tool allows us to discover several problems with DNS and hits us up with tips to fix our own problems. Got all my domains on class A with 100 in all fields.
