sedyus hi, anyone know how solved this problem with HTTPS and phpmyadmin, can pls help me? img: https://ibb.co/yRKbRyh
sedyus yes I have turned on ssl on phpmyadmin $cfg['servers'][$i]['ssl'] = true too have turned on ssl on cpanel and yes I can open this from manager but show the error mentioned
aaPanel_Jose sedyus Please try to uninstall and reinstall phpmyadmin, under normal circumstances we do not need to modify the configuration of phpmyadmin
sedyus Today Reinstall all panel from 0. click LEMP all install ok but the error with phpmyadmin persist... I don't know how solved 🙁 If you want I can send user pass for you to try test or analize img: https://ibb.co/ZKZk5zq
xlameee Hello I had the same problem just change the port from 887 to any. Seems 887 already in use with something else. Hope that helps Thank you
aaP_villasweb I have the same problem here when I changed the port. Now I can't access my database. Already re-instaled phpmyadmin 2 times, fix the panel and everything. How can I access my database from an app like Sequel?
kalino I also have a problem that phpmyadmin cannot be accessed and when changing the port there is an error message: An error occurred while the panel was running! thank you
