icr_cigas After clicking login, the panel does not load, it remains in a login loop. how can i fix without loss?
aaPanel_Kern icr_cigas Hello, Please use the SSH tool to log in to the server and execute the command to check if there are any errors: bt 14
icr_cigas Hello, Kern aaPanel_Kern. I used your tuto in this page: and that's ok! Thanks! https://www.aapanel.com/forum/d/17173-cant-login-to-the-panel-404-not-found/16
