At the same time, check the postfix configuration, which can be viewed in the server status
Put:
Change to:
or
If the display is not OK, try to save the SSL certificate again, or please re-apply for SSL
Unable to send dkim headers
Prompt for permission issues:
systemctl restart rspamd
https://www.mail-tester.com/
Sending to gmail needs to configure SSL, do DKIM, SPF, it is best to let the network provider make the PTR RDNS record of ip
