aaPanel_Jose JAY I just tested that the renewal function is working properly. Have you checked whether your DNS records are correct?
JAY aaPanel_Jose is your test on self name server hosted or different it works when its hosted on cloudflare or others problem with only self name servers
pradhan With Cloudflare proxied, This will not work I believe. Ensure you are on the grey mark and not orange and try once more and see if it works.
pradhan JAY hey Jay. Weak English - you can call it. 🙂 Sorry for the trouble and thanks for rectifying.
JAY pradhan sorry iam rude on reply i was saying that when i use selfname servers this problem is arising but not with CF or other Namservers hosting.
JAY aaPanel_Jose i think i told you already on above its not happening while using self dns hosting not cloudflare or others
aaPanel_Jose JAY Sorry I will arrange this to be tested @[deleted] Sorry, please communicate in English
aaPanel_Jose JAY Because each renewal needs to request the DNS server to automatically add a TXT record as verification, the manually verified domain name does not support renewal. We will arrange time to add a processing interface to the dns server on the panel
JAY aaPanel_Jose i renewed manually not automated i created record and tried to validate its not working after check all i posted.
aaPanel_Jose JAY The manually set record will fail to verify after clicking the renew button. This is because the renew certificate will recreate a certificate order but the record value of the new order is different from the record value of the first certificate application. We will try to solve this problem
