Since the installtion log is not showing all the log, some of logs are missing.
--2023-11-21 10:16:50-- https://node.aapanel.com/install/3/mysql.sh
Resolving node.aapanel.com (node.aapanel.com)... 2606:4700:3031::6815:4fc4, 2606:4700:3034::ac43:ab07, 172.67.171.7, ...
Connecting to node.aapanel.com (node.aapanel.com)|2606:4700:3031::6815:4fc4|:443... connected.
Length: 39347 (38K) [application/octet-stream]
Saving to: ‘mysql.sh’
0K .......... .......... .......... ........ 100% 3.40M=0.01s
2023-11-21 10:16:52 (3.40 MB/s) - ‘mysql.sh’ saved [39347/39347]
selecting download node...
https://jp1-node.bt.cn
--2023-11-21 10:17:05-- https://node.aapanel.com/install/public.sh
Resolving node.aapanel.com (node.aapanel.com)... 2606:4700:3031::6815:4fc4, 2606:4700:3034::ac43:ab07, 104.21.79.196, ...
Length: 4377 (4.3K) [application/octet-stream]
Saving to: ‘Tpublic.sh’
0K .... 100% 95.1M=0s
2023-11-21 10:17:06 (95.1 MB/s) - ‘Tpublic.sh’ saved [4377/4377]
Reading package lists...
Building dependency tree...
Reading state information...
cmake is already the newest version (3.22.1-1ubuntu1.22.04.1).
0 upgraded, 0 newly installed, 0 to remove and 99 not upgraded.
groupadd: group 'mysql' already exists
useradd: user 'mysql' already exists
--2023-11-21 10:17:20-- https://jp1-node.bt.cn/src/mysql-boost-5.7.43.tar.gz
Resolving jp1-node.bt.cn (jp1-node.bt.cn)... 45.76.53.20
Connecting to jp1-node.bt.cn (jp1-node.bt.cn)|45.76.53.20|:443... connected.
Length: 53291096 (51M) [application/octet-stream]
Saving to: ‘/www/server/mysql/src.tar.gz’
0K .......... .....
-- Looking for tell - not found
-- Looking for vasprintf
-- Looking for vasprintf - found
-- Looking for memalign
-- Looking for memalign - found
-- Looking for nl_langinfo
-- Looking for nl_langinfo - found
-- Looking for ntohll
-- Looking for ntohll - not found
-- Looking for clock_gettime
-- Looking for clock_gettime - found
-- Looking for epoll_create
-- Looking for epoll_create - found
-- Looking for inet_ntop
-- Looking for inet_ntop - found
-- Looking for kqueue
-- Looking for kqueue - not found
-- Looking for timeradd
-- Looking for timeradd - found
-- Looking for timerclear
-- Looking for timerclear - found
-- Looking for timercmp
-- Looking for timercmp - found
-- Looking for timerisset
-- Looking for timerisset - found
-- Looking for include file sys/time.h
-- Looking for include file sys/time.h - found
-- Looking for include file sys/times.h
-- Looking for include file sys/times.h - found
-- Looking for times
-- Looking for times - found
-- Looking for gettimeofday
-- Looking for gettimeofday - found
-- Looking for lrand48
-- Looking for lrand48 - found
-- Looking for TIOCGWINSZ
-- Looking for TIOCGWINSZ - found
-- Looking for FIONREAD
-- Looking for FIONREAD - found
-- Looking for FIONREAD - not found
-- Looking for SIGEV_THREAD_ID
-- Looking for SIGEV_THREAD_ID - found
-- Looking for SIGEV_PORT
-- Looking for SIGEV_PORT - not found
-- Looking for log2
-- Looking for log2 - found
-- Looking for isinf
-- Looking for isinf - found
-- Performing Test HAVE_CXX_ISINF
-- Performing Test HAVE_CXX_ISINF - Success
-- Looking for timer_create
-- Looking for timer_create - found
-- Looking for timer_settime
-- Looking for timer_settime - found
-- Looking for EVFILT_TIMER
-- Looking for EVFILT_TIMER - not found
-- Check size of char *
-- Check size of char * - done
-- Check size of long
-- Check size of long - done
-- Check size of short
-- Check size of short - done
-- Check size of int
-- Check size of int - done
-- Check size of long long
-- Check size of long long - done
-- Check size of off_t
-- Check size of off_t - done
-- Check size of time_t
-- Check size of time_t - done
-- Check size of struct timespec
-- Check size of struct timespec - done
-- Performing Test HAVE_TM_GMTOFF
-- Performing Test HAVE_TM_GMTOFF - Success
-- Check size of uint
-- Check size of uint - done
-- Check size of ulong
-- Check size of ulong - done
-- Check size of u_int32_t
-- Check size of u_int32_t - done
-- Performing Test HAVE_VISIBILITY_HIDDEN
-- Performing Test HAVE_VISIBILITY_HIDDEN - Success
-- Checking stack direction : -1
-- Looking for include files time.h, sys/time.h
-- Looking for include files time.h, sys/time.h - found
-- Looking for O_NONBLOCK
-- Looking for O_NONBLOCK - found
-- Performing Test HAVE_PAUSE_INSTRUCTION
-- Performing Test HAVE_PAUSE_INSTRUCTION - Success
-- Performing Test HAVE_BUILTIN_UNREACHABLE
-- Performing Test HAVE_BUILTIN_UNREACHABLE - Success
-- Performing Test HAVE_BUILTIN_EXPECT
-- Performing Test HAVE_BUILTIN_EXPECT - Success
-- Performing Test HAVE_BUILTIN_STPCPY
-- Performing Test HAVE_BUILTIN_STPCPY - Success
-- Performing Test HAVE_GCC_ATOMIC_BUILTINS
-- Looking for include file libaio.h
-- Looking for include file libaio.h - not found
-- Looking for io_queue_init in aio
-- Looking for io_queue_init in aio - not found
-- Performing Test HAVE_NO_BUILTIN_MEMCMP
-- Performing Test HAVE_NO_BUILTIN_MEMCMP - Success
-- Looking for sched_getcpu
-- Looking for sched_getcpu - found
-- Looking for nanosleep
-- Looking for nanosleep - found
-- Performing Test HAVE_FALLOC_PUNCH_HOLE_AND_KEEP_SIZE
-- Performing Test HAVE_FALLOC_PUNCH_HOLE_AND_KEEP_SIZE - Success
-- Performing Test HAVE_IB_GCC_SYNC_SYNCHRONISE
-- Performing Test HAVE_IB_GCC_SYNC_SYNCHRONISE - Success
-- Performing Test HAVE_IB_GCC_ATOMIC_THREAD_FENCE
-- Performing Test HAVE_IB_GCC_ATOMIC_THREAD_FENCE - Success
-- Performing Test HAVE_IB_GCC_ATOMIC_COMPARE_EXCHANGE
-- Performing Test HAVE_IB_GCC_ATOMIC_COMPARE_EXCHANGE - Success
-- Performing Test HAVE_IB_ATOMIC_PTHREAD_T_GCC
-- Performing Test HAVE_IB_ATOMIC_PTHREAD_T_GCC - Success
-- Performing Test HAVE_IB_LINUX_FUTEX
-- Performing Test HAVE_IB_LINUX_FUTEX - Success
-- Looking for asprintf
-- Looking for asprintf - found
-- Performing Test HAVE_CAST_FUNCTION_TYPE
-- Performing Test HAVE_CAST_FUNCTION_TYPE - Success
-- Performing Test HAVE_PEERCRED
-- Performing Test HAVE_PEERCRED - Success
-- Performing Test HAVE_UNUSED_TYPEDEFS
-- Performing Test HAVE_UNUSED_TYPEDEFS - Success
-- Looking for htole64
-- Looking for htole64 - found
-- Looking for htole32
-- Looking for htole32 - found
-- Looking for htole16
-- Looking for htole16 - found
-- Found PkgConfig: /bin/pkg-config (found version "0.29.2")
-- Checking for module 'libtirpc'
-- Found libtirpc, version 1.3.2
-- Performing Test HAVE_STRUCT_SOCKADDR_SA_LEN
-- Performing Test HAVE_STRUCT_SOCKADDR_SA_LEN - Failed
-- Performing Test HAVE_STRUCT_IFREQ_IFR_NAME
-- Performing Test HAVE_STRUCT_IFREQ_IFR_NAME - Success
-- Performing Test HAVE_XDR_OPS_X_PUTINT32
-- Performing Test HAVE_XDR_OPS_X_PUTINT32 - Failed
-- Performing Test HAVE_XDR_OPS_X_GETINT32
-- Performing Test HAVE_XDR_OPS_X_GETINT32 - Failed
-- Performing Test HAVECONST
-- Performing Test HAVECONST - Success
-- Performing Test HAVE_RPC_INLINE_T
-- Performing Test HAVE_RPC_INLINE_T - Success
-- Performing Test OLD_XDR
-- Performing Test OLD_XDR - Failed
-- Performing Test X_GETPOSTN_NOT_USE_CONST
-- Performing Test X_GETPOSTN_NOT_USE_CONST - Success
-- Performing Test HAS_INCOMPATIBLE_POINTER_TYPES
-- Performing Test HAS_INCOMPATIBLE_POINTER_TYPES - Success
-- Performing Test X_PUTLONG_NOT_USE_CONST
-- Performing Test X_PUTLONG_NOT_USE_CONST - Failed
-- RPC_INCLUDE_DIRS /usr/include/tirpc
-- Using Boost headers from /www/server/mysql/src/boost/boost_1_59_0
-- Performing Test CXX_HAVE_SIGN_COMPARE
-- Performing Test CXX_HAVE_SIGN_COMPARE - Success
-- Performing Test CXX_HAVE_UNUSED_VARIABLE
-- Performing Test CXX_HAVE_UNUSED_VARIABLE - Success
-- MYSQLX - Text log of protobuf messages enabled
-- Performing Test HAVE_UNUSED_PARAMETER
-- Performing Test HAVE_UNUSED_PARAMETER - Success
-- Googletest was not found. gtest-based unit tests will be disabled. You can run cmake . -DENABLE_DOWNLOADS=1 to automatically download and build required components from source.
-- If you are inside a firewall, you may need to use an https proxy: export https_proxy=http://example.com:80
-- Performing Test HAVE_MISLEADING_INDENTATION
-- Performing Test HAVE_MISLEADING_INDENTATION - Success
-- executable target mysqld debug_target /www/server/mysql/src/debug/sql/mysqld
-- Library mysqlserver depends on OSLIBS m;atomic;crypt
-- MERGE_CONVENIENCE_LIBRARIES TARGET mysqlserver
-- MERGE_CONVENIENCE_LIBRARIES LIBS dbug;strings;regex;mysys;mysys_ssl;vio;zlib;imported_openssl;imported_crypto;crypt;archive_embedded;blackhole_embedded;csv_embedded;federated_embedded;heap_embedded;innobase_embedded;lz4_lib;myisam_embedded;myisammrg_embedded;partition_embedded;ngram_parser_embedded;sql_embedded
-- MERGE_CONVENIENCE_LIBRARIES MYLIBS dbug;strings;regex;mysys;mysys_ssl;vio;zlib;imported_openssl;imported_crypto;archive_embedded;blackhole_embedded;csv_embedded;federated_embedded;heap_embedded;innobase_embedded;lz4_lib;myisam_embedded;myisammrg_embedded;partition_embedded;ngram_parser_embedded;sql_embedded
-- library target mysqlserver debug_target /www/server/mysql/src/debug/archive_output_directory/libmysqld.a
-- INSTALL mysqlclient.pc lib/pkgconfig
-- Skipping deb packaging on unsupported platform jammy.
-- CMAKE_BUILD_TYPE: RelWithDebInfo
-- COMPILE_DEFINITIONS: GNU_SOURCE;FILE_OFFSET_BITS=64;HAVE_CONFIG_H;HAVE_TLSv13
-- CMAKE_C_FLAGS: -fPIC -fabi-version=2 -fno-omit-frame-pointer -fno-strict-aliasing -Wall -Wextra -Wformat-security -Wvla -Wimplicit-fallthrough=2 -Wwrite-strings -Wdeclaration-after-statement
-- CMAKE_CXX_FLAGS: -fPIC -std=gnu++03 -fabi-version=2 -fno-omit-frame-pointer -fno-strict-aliasing -Wall -Wextra -Wformat-security -Wvla -Wimplicit-fallthrough=2 -Woverloaded-virtual -Wno-unused-parameter -Wno-class-memaccess
-- CMAKE_CXX_FLAGS_DEBUG: -DENABLED_DEBUG_SYNC -DSAFE_MUTEX -g
-- CMAKE_CXX_FLAGS_RELWITHDEBINFO: -ffunction-sections -fdata-sections -O3 -g -DNDEBUG
-- CMAKE_CXX_FLAGS_RELEASE: -ffunction-sections -fdata-sections -O3 -DNDEBUG
-- CMAKE_CXX_FLAGS_MINSIZEREL: -ffunction-sections -fdata-sections -Os -DNDEBUG
-- CMAKE_C_LINK_FLAGS:
-- CMAKE_CXX_LINK_FLAGS:
-- CMAKE_EXE_LINKER_FLAGS
-- CMAKE_MODULE_LINKER_FLAGS
-- CMAKE_SHARED_LINKER_FLAGS
-- Configuring done
[ 4%] Building C object libservices/CMakeFiles/mysqlservices.dir/security_context_service.c.o
[ 4%] Building C object libservices/CMakeFiles/mysqlservices.dir/mysql_keyring_service.c.o
[ 4%] Linking C static library ../archive_output_directory/libmysqlservices.a
[ 4%] Built target mysqlservices
[ 4%] Building CXX object sql/CMakeFiles/gen_lex_hash.dir/gen_lex_hash.cc.o
[ 4%] Linking CXX shared library ../lib/libbinlogstandalone.so
[ 4%] Building C object strings/CMakeFiles/strings.dir/dtoa.c.o
[ 4%] Built target binlogstandalone_shared
[ 4%] Building C object scripts/CMakeFiles/comp_sql.dir/comp_sql.c.o
[ 4%] Linking C executable comp_sql
[ 4%] Built target comp_sql
[ 4%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/src/gcs_plugin_messages.cc.o
[ 4%] Linking CXX executable gen_lex_hash
[ 4%] Built target gen_lex_hash
[ 4%] Generating generated/protobuf_lite/mysqlx.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_datatypes.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_connection.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_expect.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_expr.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_crud.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_sql.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_session.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_notice.proto
[ 4%] Generating generated/protobuf_lite/mysqlx_resultset.proto
[ 4%] Built target GenLiteProtos
[ 4%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/stubs/atomicops_internals_x86_gcc.cc.o
[ 4%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/src/member_info.cc.o
[ 4%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/stubs/atomicops_internals_x86_msvc.cc.o
[ 4%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/stubs/common.cc.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/int2str.c.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/is_prefix.c.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/llstr.c.o
[ 4%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/stubs/once.cc.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/longlong2str.c.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/my_strtoll10.c.o
[ 4%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/stubs/stringprintf.cc.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/my_vsnprintf.c.o
[ 4%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/extension_set.cc.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/str2int.c.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/str_alloc.c.o
[ 4%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/src/member_version.cc.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/strcend.c.o
[ 4%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/src/compatibility_module.cc.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/strend.c.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/strfill.c.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/strmake.c.o
[ 4%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/gcs_logging.cc.o
[ 4%] Building C object strings/CMakeFiles/strings.dir/my_stpmov.c.o
[ 5%] Building C object strings/CMakeFiles/strings.dir/my_stpnmov.c.o
[ 5%] Building C object strings/CMakeFiles/strings.dir/strxmov.c.o
[ 5%] Building C object strings/CMakeFiles/strings.dir/strxnmov.c.o
[ 5%] Building C object strings/CMakeFiles/strings.dir/xml.c.o
[ 5%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/xplatform/my_xp_cond.cc.o
[ 5%] Building C object strings/CMakeFiles/strings.dir/my_strchr.c.o
[ 5%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/xplatform/my_xp_thread.cc.o
[ 5%] Building C object strings/CMakeFiles/strings.dir/strcont.c.o
[ 5%] Building C object strings/CMakeFiles/strings.dir/strappend.c.o
[ 6%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/xplatform/my_xp_mutex.cc.o
[ 6%] Linking C static library ../archive_output_directory/libstrings.a
[ 6%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/xplatform/my_xp_util.cc.o
[ 6%] Built target strings
[ 6%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/code_generator.cc.o
[ 6%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/gcs_view.cc.o
[ 6%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/generated_message_util.cc.o
[ 6%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/message_lite.cc.o
[ 6%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/command_line_interface.cc.o
[ 6%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/repeated_field.cc.o
[ 6%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/gcs_types.cc.o
[ 6%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/wire_format_lite.cc.o
[ 6%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/gcs_message.cc.o
[ 7%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/io/coded_stream.cc.o
[ 7%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/io/zero_copy_stream.cc.o
[ 7%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/gcs_member_identifier.cc.o
[ 7%] Building CXX object extra/protobuf/CMakeFiles/protobuf-lite.dir/protobuf-2.6.1/src/google/protobuf/io/zero_copy_stream_impl_lite.cc.o
[ 7%] Building CXX object rapid/plugin/group_replication/CMakeFiles/gr_unit_test_resource.dir/libmysqlgcs/src/interface/gcs_group_identifier.cc.o
[ 7%] Linking CXX static library ../../archive_output_directory/libprotobuf-lite.a
[ 7%] Built target protobuf-lite
[ 7%] Building CXX object extra/protobuf/CMakeFiles/protobuf.dir/protobuf-2.6.1/src/google/protobuf/stubs/strutil.cc.o
[ 7%] Linking CXX static library ../../../archive_output_directory/libgr_unit_test_resource.a
[ 7%] Built target gr_unit_test_resource
[ 7%] Building CXX object extra/CMakeFiles/lz4_decompress.dir/lz4_decompress.cc.o
[ 7%] Linking CXX executable lz4_decompress
[ 7%] Built target lz4_decompress
[ 7%] Building CXX object extra/CMakeFiles/zlib_decompress.dir/zlib_decompress.cc.o
[ 8%] Linking CXX executable zlib_decompress
[ 8%] Built target zlib_decompress
[ 8%] Generating mysql_fix_privilege_tables_sql.c
[ 8%] Generating sql_commands_sys_schema.h
[ 8%] Built target GenFixPrivs
[ 8%] Building CXX object client/dump/CMakeFiles/boost_lib.dir///include/boost_1_59_0/libs/chrono/src/chrono.cpp.o
[ 8%] Building CXX object extra/protobuf/CMakeFiles/protobuf.dir/protobuf-2.6.1/src/google/protobuf/stubs/substitute.cc.o
[ 8%] Building CXX object client/dump/CMakeFiles/boost_lib.dir///include/boost_1_59_0/libs/system/src/error_code.cpp.o
[ 8%] Building CXX object extra/protobuf/CMakeFiles/protobuf.dir/protobuf-2.6.1/src/google/protobuf/stubs/structurally_valid.cc.o
[ 9%] Building CXX object extra/protobuf/CMakeFiles/protobuf.dir/protobuf-2.6.1/src/google/protobuf/descriptor.cc.o
[ 9%] Linking CXX static library ../../archive_output_directory/libboost_lib.a
[ 9%] Built target boost_lib
[ 10%] Generating lex_hash.h
[ 10%] Built target GenYaccEmbeddedSource
[ 10%] Building CXX object mysql-test/lib/My/SafeProcess/CMakeFiles/my_safe_process.dir/safe_process.cc.o
[ 10%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/cpp/cpp_file.cc.o
[ 10%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/cpp/cpp_generator.cc.o
[ 10%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/cpp/cpp_helpers.cc.o
[ 10%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/cpp/cpp_message.cc.o
[ 10%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/cpp/cpp_message_field.cc.o
[ 10%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/cpp/cpp_primitive_field.cc.o
[ 10%] Building CXX object extra/protobuf/CMakeFiles/protobuf.dir/protobuf-2.6.1/src/google/protobuf/descriptor.pb.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/cpp/cpp_service.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/cpp/cpp_string_field.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_context.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_enum.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_enum_field.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_extension.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_field.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_file.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_generator.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_generator_factory.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protobuf.dir/protobuf-2.6.1/src/google/protobuf/descriptor_database.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_helpers.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_lazy_message_field.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_message.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_message_field.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protobuf.dir/protobuf-2.6.1/src/google/protobuf/dynamic_message.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_name_resolver.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protobuf.dir/protobuf-2.6.1/src/google/protobuf/extension_set_heavy.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_primitive_field.cc.o
[ 11%] Building CXX object extra/protobuf/CMakeFiles/protoclib.dir/protobuf-2.6.1/src/google/protobuf/compiler/java/java_shared_code_generator.cc.o
[ 34%] Building C object storage/myisam/CMakeFiles/myisam_embedded.dir/mi_scan.c.o
[ 34%] Building C object storage/myisam/CMakeFiles/myisam_embedded.dir/mi_search.c.o
[ 34%] Building CXX object storage/innobase/CMakeFiles/innobase_embedded.dir/data/data0data.cc.o
[ 34%] Building C object storage/myisam/CMakeFiles/myisam_embedded.dir/mi_static.c.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/libmysqlgcs/src/bindings/xcom/gcs_xcom_group_member_information.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/libmysqlgcs/src/bindings/xcom/gcs_message_stages.cc.o
[ 63%] Building CXX object rapid/plugin/x/CMakeFiles/mysqlx.dir/src/query_string_builder.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/libmysqlgcs/src/bindings/xcom/gcs_xcom_view_identifier.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/libmysqlgcs/src/bindings/xcom/gcs_xcom_interface.cc.o
[ 63%] Building CXX object rapid/plugin/x/CMakeFiles/mysqlx.dir/src/expr_generator.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/libmysqlgcs/src/bindings/xcom/gcs_xcom_notification.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/libmysqlgcs/src/bindings/xcom/gcs_message_stage_lz4.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/libmysqlgcs/src/bindings/xcom/gcs_xcom_statistics_interface.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/src/applier.cc.o
[ 63%] Building CXX object rapid/plugin/x/CMakeFiles/mysqlx.dir/src/crud_cmd_handler.cc.o
[ 63%] Building CXX object rapid/plugin/x/CMakeFiles/mysqlx.dir/src/buffering_command_delegate.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/src/auto_increment.cc.o
[ 63%] Building CXX object rapid/plugin/x/CMakeFiles/mysqlx.dir/src/callback_command_delegate.cc.o
[ 63%] Building CXX object rapid/plugin/x/CMakeFiles/mysqlx.dir/src/streaming_command_delegate.cc.o
[ 63%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/src/certifier.cc.o
[ 64%] Building CXX object rapid/plugin/x/CMakeFiles/mysqlx.dir/src/sql_data_context.cc.o
[ 64%] Building CXX object rapid/plugin/x/CMakeFiles/mysqlx.dir/src/sql_data_result.cc.o
[ 64%] Building CXX object rapid/plugin/group_replication/CMakeFiles/group_replication.dir/src/channel_observation_manager.cc.o
[ 72%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/conn_handler/connection_handler_manager.cc.o
[ 72%] Building CXX object sql/CMakeFiles/sql.dir/sql_hints.yy.cc.o
[ 72%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/datadict.cc.o
[ 72%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/debug_sync.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/derror.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/discover.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/field.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/field_conv.cc.o
[ 73%] Building CXX object sql/CMakeFiles/sql.dir/sql_builtin.cc.o
[ 73%] Building CXX object sql/CMakeFiles/sql.dir/abstract_query_plan.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/filesort.cc.o
[ 73%] Building CXX object sql/CMakeFiles/sql.dir/auth/sql_authentication.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/filesort_utils.cc.o
[ 73%] Building CXX object sql/CMakeFiles/sql.dir/auth/sql_auth_cache.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/aggregate_check.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/geometry_rtree.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/gstream.cc.o
[ 73%] Building CXX object libmysqld/CMakeFiles/sql_embedded.dir//sql/handler.cc.o
[ 73%] Building CXX object sql/CMakeFiles/sql.dir/auth/sql_authorization.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/sql_insert.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/sql_join_buffer.cc.o
[ 91%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/object_filter.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/sql_lex.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/sql_lex_hash.cc.o
/www/server/panel/pyenv/lib/python3.7/site-packages/setuptools/command/easy_install.py:147: EasyInstallDeprecationWarning: easy_install command is deprecated. Use build and pip and other standards-based tools.
EasyInstallDeprecationWarning,
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/PyMySQL-0.9.3-py3.7.egg' and adding 'build/bdist.linux-x86_64/egg' to it
removing 'build/bdist.linux-x86_64/egg' (and everything under it)
Processing PyMySQL-0.9.3-py3.7.egg
copying build/lib/pymysql/constants/FLAG.py -> build/bdist.linux-x86_64/egg/pymysql/constants
copying build/lib/pymysql/constants/FIELD_TYPE.py -> build/bdist.linux-x86_64/egg/pymysql/constants
copying build/lib/pymysql/constants/ER.py -> build/bdist.linux-x86_64/egg/pymysql/constants
copying build/lib/pymysql/constants/COMMAND.py -> build/bdist.linux-x86_64/egg/pymysql/constants
copying build/lib/pymysql/constants/CR.py -> build/bdist.linux-x86_64/egg/pymysql/constants
copying build/lib/pymysql/compat.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/connections.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/err.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/socketio.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/init.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/auth.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/protocol.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/cursors.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/times.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/charset.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/util.py -> build/bdist.linux-x86_64/egg/pymysql
copying build/lib/pymysql/converters.py -> build/bdist.linux-x86_64/egg/pymysql
byte-compiling build/bdist.linux-x86_64/egg/pymysql/optionfile.py to optionfile.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/constants/SERVER_STATUS.py to SERVER_STATUS.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/constants/CLIENT.py to CLIENT.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/constants/init__.py to init.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/constants/FLAG.py to FLAG.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/constants/FIELD_TYPE.py to FIELD_TYPE.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/constants/ER.py to ER.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/constants/COMMAND.py to COMMAND.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/constants/CR.py to CR.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/compat.py to compat.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/connections.py to connections.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/err.py to err.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/socketio.py to socketio.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/init.py to init.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/auth.py to _auth.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/protocol.py to protocol.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/cursors.py to cursors.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/times.py to times.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/charset.py to charset.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/util.py to util.cpython-37.pyc
byte-compiling build/bdist.linux-x86_64/egg/pymysql/converters.py to converters.cpython-37.pyc
creating build/bdist.linux-x86_64/egg/EGG-INFO
copying PyMySQL.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
copying PyMySQL.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying PyMySQL.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying PyMySQL.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying PyMySQL.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
/www/server/panel/pyenv/lib/python3.7/site-packages/setuptools/config/setupcfg.py:508: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
warnings.warn(msg, warning_class)
/www/server/panel/pyenv/lib/python3.7/site-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
creating dist
Copying PyMySQL-0.9.3-py3.7.egg to /www/server/panel/pyenv/lib/python3.7/site-packages
Adding PyMySQL 0.9.3 to easy-install.pth file
Installed /www/server/panel/pyenv/lib/python3.7/site-packages/PyMySQL-0.9.3-py3.7.egg
Processing dependencies for PyMySQL==0.9.3
Finished processing dependencies for PyMySQL==0.9.3
Reload Bt-Panel.. [32mdone[0m
Stopping mysqld (via systemctl): mysqld.service.
Changing password...
2023-11-21T10:29:12.788892Z mysqld_safe Logging to '/var/log/mysql/error.log'.
2023-11-21T10:29:12.806664Z mysqld_safe Starting mysqld daemon with databases from /www/server/data
2023-11-21T10:29:13.166044Z mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (111)
Starting mysqld (via systemctl): mysqld.serviceJob for mysqld.service failed because the control process exited with error code.
See "systemctl status mysqld.service" and "journalctl -xeu mysqld.service" for details.
failed!
The root password set 04a5be8672a195ab successuful
1
2023-11-21T10:29:21.861016Z mysqld_safe Logging to '/var/log/mysql/error.log'.
2023-11-21T10:29:21.876837Z mysqld_safe Starting mysqld daemon with databases from /www/server/data
2023-11-21T10:29:22.224915Z mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
failed!
1
failed!
mysql: [Warning] Using a password on the command line interface can be insecure.
