Hello, please check if your IP is correct? File verification requires the SSL provider to access your website
It is recommended that you use DNS verification. Is this a solution? Add according to the prompts.
After adding, you need to wait for a while for it to take effect. Finally, return to the interface for manually adding txt records and verify the dns records.
aaP_melissa
