• DiscussionGeneral
  • Database Does Not Remove Upon Removal of Domain Installed with One Click Install
Hi
I have noticed a bug, that database does not get removed when we remove the domain name from websites section, which was installed using one click install, despite it asks for removal of database + root directory + FTP.
Database has to be manually removed. If we have enabled recycle bin for database, in that case, similar database cannot be created as well, unless you trash the recycle bin to remove that database from recycle bin.
There should be a proper one click uninstaller as well, which should remove or uninstall the scripts installed via one click install manager, so that these bugs can be tackled.
    szone
    1. When you click Delete Site, if you choose to delete the database at the same time, the database will be deleted.
    2. If the recycle bin is enabled, the database will be deleted and enter the recycle bin, but in fact the database still exists in mysql, so the database with the same name cannot be created, and the database must be completely deleted.
    At present, the database recycle bin is not perfect, it is only used to prevent users from misoperation.
    We will try to perfect it when appropriate.
    8 days later
