aaPanel_Jose
you need to adjust the time and timezone settings ,it is very important, all times in database will be incorrect even if the developer used [ date_default_timezone_set(''); ]
all timezones are incorrect because utc time is incorrect
and server time option in settings tab has (sync ) button !!! why? sync with what? its horrible button and destroy everything . i am afraid to click this button by mistake . i think that you should do 2 things
1- when user installing aapanel , NTP synchronized should be automaticly (yes) (enabled) , this will make utc time correct and vestacp doing this also
2- remove sync button beside servertime option
